Inventor Forum
Cylinder Reinforcing
12 REPLIES 12
Message 1 of 13
JJarbeau
523 Views, 12 Replies
Hello
I tried to model an angular flat bar reinforcement of a cylinder. I managed to create a part that will be OK. The problem is the shop spends hours grinding a chamfer from 1/2 x 1/2, at the ends, tapering down to a zero chamfer at the intersection. Any way I can export a flat pattern without
grinding the chamfers? The Flat bars are 1/2 thick and 3 wide and need to span 36". The cylinder ID 42-7/8 x 43 long. Cant figure out how to upload file/s.
12 REPLIES 12
Message 2 of 13
mcgyvr
in reply to: JJarbeau
Any help would be greatly appreciated. Thanks in advance
When you posted or reply see the "Attachments" section
Message 3 of 13
JJarbeau
I attached the assembly but I cant remember how to include all the parts.
Message 4 of 13
mcgyvr
File..save as.. pack and go
Or just zip up all the ipt files,etc.. into a zip folder and post that too..
the iam is useless without the parts..
Message 5 of 13
JJarbeau
Zipped files are too big. Doesn't Autodesk have a "Dropbox" type app?
Message 6 of 13
mcgyvr
Do the pack and go again and this time check "skip libraries, skip styles, skip templates"... That should make it much smaller..
Message 7 of 13
JJarbeau
in reply to: mcgyvr
OK got it
Thanks for the help
Message 8 of 13
kelly.young
@JJarbeau thanks for sharing the files. Are you talking about the chamfer on the inside and outside of the curved piece?
I messed around with this for a bit, the issue is that the lower end curves different than the upper.
I tried to use Loft with center rail and it worked pretty well.
I thought about creating a surface and then thicken but it needs to go both directions and then they didn't meet in the middle. Used Patch then Sculpt to fix the gap, but didn't look right.
Might give you an idea of how to go about creating the crossing pieces.
In the assembly, right click on the part and Replace Component with the attached ones (I suppressed the link so it is not constrained anymore).
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 9 of 13
IgorMir
Here is what I can suggest in order to get the straight edges for the reinforcement bar. Please see the attached files.  I have derived the rib you have got into a new file and then - offset one of the surface. Then trim the resulting solid to make it uniform width. Since the part is flat already by the way it is modeled - there is no need for a Flat Pattern. But you probably will need to twik it a bit to suit the cylinder.
Cheers,
Igor.
@JJarbeau wrote:
Hello
Web: www.meqc.com.au
Message 10 of 13
IgorMir
in reply to: kelly.young
Thanks for the kudo, Kelly.  🙂
I looked at what you have suggested - the rib is not flat. It has a twist in it. My part is flat but there is an interference between the rib and the cylinder when assembled. That interference can probably be dealt with on the shop floor. But I will have a look into better modelling of the item later on.
Cheers,
Igor.
Message 11 of 13
IgorMir
Hello again...
Here is an another attempt of mine.  Is that model sufficient enough for your purposes?
Cheers,
Igor.
@JJarbeau wrote:
Hello
Message 12 of 13
JJarbeau
in reply to: IgorMir
Thanks Igor. I thought I would need to split the reinf into 4 pcs but couldn't wrap my head around it.
Cheers
Message 13 of 13
IgorMir
I would suggest - two iParts instead. Attached is an example of it.
Cheers,
Igor.
Cheers
