Cutting through a revolve
Message 1 of 13
There must be some simple reason, but I give up.  I can't seem to cut through my revolve feature.  It's a bowl, which I'm trying to add a pouring spout to, but any sketch I try to extrude/cut through it with does not work.  It gives me an error.  I even tried experimenting with ANYTHING - a simple circle on the plane below, to come up and cut a hole in it.  Still doesn't work!  What in the world am I missing??  (I'm using Inventor LT.)
Frank
Replies (12)
Message 2 of 13
blair
Pretty tought without looking at the model or what you are doing. Is your cut process going the the correct direction?
Post your part as well.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 13
Yes, it's going in the correct direction. I can see it kind of ghosted out
going through. but then disappears, with an error.
Message 4 of 13
blair
Can you post some screen captures of what you are seeing/doing.
Delta Tau Chi ΔΤΧ
Message 5 of 13
These show the attempt at the spout, but even trying to cut a simple hole anywhere will fail.   ??
Message 6 of 13
SBix26
Notice in your browser that you have one solid and two surfaces.  You are trying to perform a solids operation (extrude/cut) on a surface body.  Make the bowl solid, then it will work.
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 7 of 13
Hummm....  Interesting.
I guess I ended up with that because it doesn't allow me to choose the solid option - only the surface, for some reason (as new attached shows.)  ??
Message 8 of 13
wilkhui
Additionally, if you expand the error message it'll give a rough idea of what's going wrong.
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Message 9 of 13
wilkhui
Hi Frank,
The message in RevolveTest-2 is because the profile you've created is open. I'm guessing it's missing an edge where it joins the axis you're using, if you add that edge it should let you make the solid revolution.
As an aside, it helps to attach the .ipt and a video of what you're doing, I usually use Screencast.
Hope this helps,
Indy
Product Owner - ASM
Message 10 of 13
Hah!  I now realized WHY it wasn't allowing it to be the "solid" option...  I needed to close it with a line at the axis (see attached.)
Well, I figured it was some stupid mistake 🙂  So, now it's a solid, and I can cut thru it. Thanks!
I'm somewhat new with this, so I'll probably be bugging you guys quite a bit...  hope that will be okay... 🙂
Message 11 of 13
Yep. Just realized that too. Thanks, so much!
Message 12 of 13
wilkhui
    I'm somewhat new with this, so I'll probably be bugging you guys quite a bit...  hope that will be okay... Smiley Happy
Of course, everyone is on this community to help, glad you've had a good first experience.
Since you're new, it's a good idea just to run through the guided tutorials. If you've already done them then there's loads of other material online (I won't start naming websites but other readers please feel free to suggest your favourites).
Cheers!
Indy
Product Owner - ASM
Message 13 of 13
Your solution work very well I was having a similar problem thank you very much
