Message 1 of 10
04:42 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've created this cylinder:
I've then modeled a solid as a separate lofted body:
I have then deleted top face and it turned to a surface body. I want to cut the cylider using the split command (solid cut) but Inventor doesn't accept surface body that was generated after deleting one solid body face.
I then modeled a revolved surface body from scratch:
In this case split command accepts it:
What's different in the surface body that was generated after deleting one solid face that doesn't make Inventor accept it as a selectable surface body in the split command ?
In attach is the file.
