Cutting a hole from another part
- Mute
- Permalink
- Report
I wonder: is it possible to define a part such that, when included in an assembly, it cuts features from the parts already in that assembly?
To avoid an XY problem, I'll explain what I'm trying to achieve. I'd like to define a part that mounts to another one, e.g. a solid base. My part has mounting holes, and I'd like to define tapped holes in the base which match the clearance holes in the part. I know that I could simply place the part on the base then define tapped holes which mate to the part's clearance holes. However, I'll need to place this part many times and that's an error-prone step. Can I define the holes in the part somehow such that placing it into the assembly causes the correct holes to be drilled into the base?
Thanks a lot!
