- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'd like to cut this Celtic knot pattern (Sketch 20) into the loop of this ring, so that it cuts all the way through. Eventually I'd like it to be symmetrical on both sides. I can't seem to select the profile using the Emboss or Extrude features.
I used Aspire to create the vectors, by converting a raster, and imported those vectors through a DXF file. Short of hand-drawing each of these curly shapes, is there a way I can use what I have to make this cut?
Alternatively, I was able to project the shapes onto the ring as you can see in 3D Sketch 2. Is there a way to use that 3D sketch to cut out the shapes?
Final question - it's just a bit too long on the Z axis. Is there a simple way to compress the entire graphic along one dimension, or would that need to come at an earlier stage?
