Custom Style set as default
Jacques.Grobler
Jacques.Grobler
Hi all
I have created a cutom style to my company's preferences, and I have exported this style
Now I am trying to create a title block and use the same style to make a default drawing template
But I keep getting the msg attached...
Please assist
Jacques.Grobler
I have tried the below procedure but get the same problem:
http://synergiscadblog.com/2013/04/04/avoid-drawing-template-style-conflicts-inventor-2013/
CCarreiras
Hi!!
Repete the process carefully... it must work.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Jacques.Grobler
Hi Carlos
It worked in the end but I started my style and template from scratch
