Custom style library
lkirit2000
Advisor Advisor
Message 1 of 11
lkirit2000
Hi Team,
I have created a custom style library and set it as active in my drawing template. However, I am currently working on a drawing that was copied from an older drawing, and I cannot see the custom style library in this drawing.
Could you please advise how I can make the custom style library available in the copied drawing?
Kiri
Replies (10)
Message 2 of 11
James_Willo
Have you tried the 'update' button? This will copy the central style library over the one in your current drawing.
James W
Inventor UX Designer
Message 3 of 11
lkirit2000
Yes, it doesn't show up my custom style library in the style editor
Message 4 of 11
James_Willo
Not sure if this helps
https://inventorfasttips.blogspot.com/2021/08/style-library-conflicts.html
James W
Message 5 of 11
blandb
Did you save your changed to the style library?
Autodesk Certified Professional
Message 6 of 11
obulesub
Hi @lkirit2000 ,
It looks like the suggestions shared so far didn't fully resolve the issue, and a couple of follow-up questions were asked to help narrow things down. If you're still experiencing this problem, could you provide an update on what you found and whether you were able to check those items? That should help the community continue investigating.
Obulesu | Community Manager
Message 7 of 11
lkirit2000
Hi Team,
I have created a lot of drawings using an older template. If I delete that template, will it affect any of the existing drawings that were created using it?
Message 8 of 11
AEtzkorn
The drawings you created with the old template will remain.  Deleting it only deletes the instance in your Templates folder.  The rest of the files all maintain that data internally and do not return to the template file.  You could create your new template and use "Drawing Transfer Wizard" to update the ones you want to change.  I have recently started using that when my company updates our template.
ALAN ETZKORN
CAD Administrator/Design Engineer
o: 260-422-8767 ext 322
725 E. Parr Rd., Berne, IN 46711
www.MarineEquipmentSolutions.com
Message 9 of 11
lkirit2000
Hi
Thanks for your response.
I have a custom style in one template. How to bring this style to other template ?
Message 10 of 11
James_Willo
You could try this (use which ever version matches):
James W
Message 11 of 11
James_Willo
There's also this:
James W
