Custom properties drop down value
roark_shawn80
Observer Observer
Message 1 of 9
roark_shawn80
Observer
Observer
Is there a way to make a custom iproperty
have a dropdown value.
example
Type: Text
Value:
  • Basement
  •  1st floor
  •  2nd floor
  • Attic
  • Etc..
Replies (8)
Message 2 of 9
CCarreiras
Hi!
It's not possible, but it's possible to do that with an iLogic Form and an iLogic Rule.
CCarreiras
Message 3 of 9
M_Santi
How would you do that?
Message 4 of 9
CGBenner
@roark_shawn80 @M_Santi
Welcome to the forum!  I found this YouTube from about a year ago that describes how to do a simple form with multi value parameters.  It looks easy enough that even I could do it.  😂
[video]
Chris Benner
Message 5 of 9
CCarreiras
@CGBenner , they are looking for a diferent thing... multivalue values, but... in iProperties Custom Parameters, not in the  Fx Parameters chart.
CCarreiras
Message 6 of 9
roark_shawn80
Observer
Observer
     I would like a drop down list of standard text I use in all my files to keep everything standardized instead or typing them in all the time. It would save time with typing and during drawing checking to make sure everything is fill out the same.  I can do this in Creo or in Solidworks using the custom property tab builder.
I can’t find how to use illogic to make this type of property.
Message 7 of 9
A.Acheson
Drop down listbox does not exist for custom iproperties unfortunately. The only built in functionality which is a workaround is to load your multivalue text values into a parameter and then place that parameter in a local or global form. This allows selection of the parameter and that's it. To get the parameter as a custom iProperty, unfortunately you cannot use the export parameter tick box as it does not exist for Text parameters although on the wish list for years. This needs an ilogic rule either internal or external. to pass the parameter to the custom iProperty.
Form Setup:
Rule Setup
iProperties.Value("Custom", "CustomText1") = TextParameter1
iProperties.Value("Custom", "CustomText2") = TextParameter2
MessageBox.Show("All Done. Check The iProperty", "iLogic")
Another self contained method  using code only is to set up a list then retrieve it using an InputListBox and then send it to the custom iproperty.
Dim List as New List (Of String)
List.Add("Text1")
List.Add("Text2")
Dim CustomText as String  = InputListBox("Prompt",List, defaultEntry, Title := "Dialog Title", ListPrompt := "List Prompt")
iProperties.Value("Custom", "CustomText") = CustomText
Result
Here is a link to a video with a variation of this but using a parameter.
Regards
Alan
Message 8 of 9
roark_shawn80
Observer
Observer
Thanks!
Message 9 of 9
jwoutersJC4LN
is this video still available somewhere?
