Custom leader with file name
Is it possible to create a custom leader/balloon that will extract the filename of a sub-assembly and/or part.
Yes, I think it can be done. As well in a leader as in your partlist
Here it is explained with custom iproperties, but it also works with normal iproperties.
https://forums.autodesk.com/t5/inventor-forum/how-to-add-custom-iproperty-to-parts-list/td-p/3294707
https://forums.autodesk.com/t5/inventor-forum/custom-iproperties-in-leader-text/m-p/6837509
Lewis.Young
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Here comes the tricky part.
I'm in a position where I would like to have the filename of my sub-layouts in my leader, BUT on my parts list, I'd like to unfold my sub-layouts, so that I can see the components of my layout
johnsonshiue
Hi! If I understood you request correctly, you will need to create a second drawing view based on the subassembly itself. Then create a partslist based on such view. I am sorry I am a bit confused with the term "Unfold." Could you elaborate it? Is it unfolding in Sheet Metal or expanding the nodes in the partslist?
Many thanks!
Software Test Engineer
