Custom iProperties
Custom iProperties
premysl.misun
Custom iProperties
premysl.misun
Hi all,
for my customer I have to make one iProperty and I want to be the same as default keyword form iProperties. Is this possible by simple formula? If new iProperty can not be keyword, can be keyword same as new iProperty by simple formula?
In attachment is pictury what i mean.
Thank you fro your help.
cbenner
@premysl.misun
You can assign a value to the Custom iproperty, and then give Keywords the value as:  =<custom>  Replace "custom" with the name of your custom iproperty.  It will not work the other way around.
premysl.misun
Thank you 😉
mcgyvr
edit: doh'.. too late..
Create a new iproperty and type in =<Keywords> and then press apply and close the iproperties dialog box..
When you open it up again it will show whatever is in the Keywords field..
For some reason hitting apply doesn't force Inventor to use the iproperty expression and you must close the box and go back in..
premysl.misun
It is probably better solution for me 😉
