Custom fields in model tree (i.e. not part number/file name)
IC96
Message 1 of 8
IC96
My company uses a randomly generated number for parts and file names. When I'm in an assembly the model tree is just a list of numbers, it can get confusing.
Is there a way to have Inventor display the title of the part in the model tree instead of part number/file name?
Running Inventor 2018
Cheers
Replies (7)
Message 2 of 8
Cadmanto
Not out of the box, but this thread might help you in getting the description to show up in the browser.
https://forums.autodesk.com/t5/inventor-forum/displaying-part-description-in-feature-tree/td-p/63507...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
swalton
I don't think that there is a way out-of-the-box to change a component's display name from either its filename or part number to its description.
iLogic to the rescue!?
This thread may give you a good start:
https://forums.autodesk.com/t5/inventor-forum/changing-occurrence-name-for-multiple-parts/td-p/54096...
You might want to post your question in the Inventor Customization forum.
I think it is a good idea to keep the part number/filename as part of your new display name.  I would get very lost in an assembly that did not keep that information in front of me.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 4 of 8
Curtis_Waguespack
Hi @IC96
To do this for all occurrences in the assembly you can use something like this example ilogic code.
This rule catches errors when the title iproperty is empty, and it also adds an instance number with a colon, so that no errors occur from trying to name multiple occurrences of the same part the same thing.
Note I would make this an external rule and run it on the assembly...  and you might set it to run on the 'Before Save' event trigger.
I hope this helps.
Curtis
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
i=1
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
		Try
		oOcc.Name = iProperties.Value(oOcc.Name, "Summary", "Title") & ":" & i
		Catch
		'catch errors ( such as empty title iprop value ) and do nothing
		End Try
		i=i+1
Next
Message 5 of 8
Curtis_Waguespack
This is a good point, maybe something like this to toggle between Title and Part Number would be best:
oInput = InputRadioBox("Set browser names as?", "Title", "Part Number", True, "iLogic")
i=1
	If oInput = True Then
		sText = iProperties.Value(oOcc.Name, "Summary", "Title")
	Else
		sText = iProperties.Value(oOcc.Name, "Project", "Part Number")
	Try
	oOcc.Name = sText  & ":" & i
	Catch
	End Try
	i=i+1
Next
Message 6 of 8
IC96
Thanks mate, this is exactly what I was after
Message 7 of 8
I was looking for this solution but I am having trouble running the macro.
Could someone please assist me running this macro or i logic rule?
I dont know how.
Thanks!
Message 8 of 8
johnsonshiue
Hi! Another option is to install an existing app. Please take a look at the following browser related apps.
https://apps.autodesk.com/INVNTOR/en/List/Search?isAppSearch=True&searchboxstore=INVNTOR&facet=&coll...
Many thanks!
Software Test Engineer
