Good morning,
I am working in an assembly with 3 parts (each a 2D surface patch), I placed the 2 gears (left one grounded), second one Flush to same plane, spaced using mate at 4.4375" (gear center distance). I created a tangent constraint at gear face edge, added a rotation motion constrain between the 2 gears and then deleted the tangent constraint. I could rotate the first gear around the second no problem, worked as intended.
I then added the link to the model, mated the point and axis to the left gear.
When I mate the point of the linkage to the point of the center gear, the rotation motion constraint relative to each other fails and the right gear rotates with respect to the link, but not the left gear.
Is there a hierarchy for constraints?
H.
