Hi all,
I'm creating a Drawing Template to fit my needs for a school project, but I'm notable to get the ITEM possition on the part list.
If I do a test with the ANSI template included on Inventor, the Part List works and it shows the ITEM fields.
On my configuration I'm don't get this ITEM field to add to my Part List configuration.
Any ideas what I heve missed?
I have done a small video for better understanding.
(I'm using Inventor Student Version)
Solved by kelly.young. Go to Solution.
Hello @ARamos08 !
Welcome to Autodesk Communities!
Great to see your questions, hope you will find a solution soon!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Hi don't understand why I don't get the ITEM propertie to select on my template to add ti my part list 😞
Hello @ARamos08 I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
If you can attach your .idw template to investigate further that would be helpful.
What standard did you begin with for this template? It is usually there by default, did the ITEM column somehow get deleted from the referenced model or the name changed?
Please select the Accept Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
Hello @ARamos08 thanks for attaching the drawing file.
It appears that the ITEM and QTY in a standard Parts List were converted to Pos. and Pos. for this template setup. (Qant. reports same as QTY.) A simple test is to add all columns and see what they are reporting.
I cannot explain, but it does seem to be reporting the correct info when used.
Did this happen out of the box, or did you tinker with it for a while and get it to happen?
Thanks Kelly Young,
I don't have any idea how this appned. Also I don't know how to reset this.
That solved the problem.
ARamos
