Hello
I am trying to use the length in the description of all the created profiles from Content Center. When I insert a content center profile there is no problem, the system recognises the B_L parameter alocated in the content center table.
But when I use the frame generator, the length information disappears from the description. Is there a way to solve it? Maybe using G_L from the model? I am not able to use this parameter in the content center since it is a reference parameter inside the part. I also give inormation of the length on the filename and partnumber, and in those fields everything is working OK.
Table on the content center:
Filename (working OK):
Description (not working when using frame generator):
If I need to use the G_L parameter within the model, how can I do that? Since it is not declarated on the content center table, I don't know how to use it.
