Custom content center, frame generator, G_L
xavi.saus
xavi.saus
Hello
I am trying to use the length in the description of all the created profiles from Content Center. When I insert a content center profile there is no problem, the system recognises the B_L parameter alocated in the content center table.
But when I use the frame generator, the length information disappears from the description. Is there a way to solve it? Maybe using G_L from the model? I am not able to use this parameter in the content center since it is a reference parameter inside the part. I also give inormation of the length on the filename and partnumber, and in those fields everything is working OK.
Table on the content center:
Filename (working OK):
Description (not working when using frame generator):
If I need to use the G_L parameter within the model, how can I do that? Since it is not declarated on the content center table, I don't know how to use it.
CGBenner
@xavi.saus
The naming convention in the Content Center will be used to name files that are created when Placing a member individually from the Content Center, but not for Frame Generator.  Frame Generator has a different set of file naming rules that can be set in your Inventor Application Options, under the File Tab.  At the bottom you will see File Naming Defaults.  Here you can set File Naming for Frame Generator and Tube & Pipe, as well as Mirror and Copy.
Chris Benner
