Inventor Forum
Custom Balloon Shape Insertion Point
5 REPLIES 5
1272 Views, 5 Replies
Does anyone know the answer to the question asked here by @Yuka_Asao? (scroll down)
I'd like to make a custom balloon that looks exactly like this and I don't think it is possible.
Thanks.
Alex
Tags (1)
5 REPLIES 5
As far as I know, that is only possible in Inventor 2016. See link below for further info in how to do it:
http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016/...
Thank you for your reply @Anonymous. It is not possible in Inventor 2016 to do what I or @Yuka_Asao are trying to do which is create a custom balloon and specify where the iProperties show up in that custom balloon.
It may be able to be accomplished with iLogic maybe...? Not sure though.
i'm not sure cause I didn't investigate 2016 that much...With iLogic I beleive it's possible, I'll try and if i accomplish i'll let you know.
Meanwhile maybe someone will get the answer..
Yuka_Asao
I guess it is impossible to define where each property is placed.
Can I place properties as attributes in a block like AutoCAD?
I don't want to use iLogic.
This new enhancement on 2016 is good but not enough.
I would like the develpment team to find and answer this topic...
emailJC9H5
in reply to: Yuka_Asao
Has this be solved as the links no longer work?
