Curve driven pattern
J.Oye
J.Oye
I've attached a screenshot of a sheetmetal part where I have a hole placed centered at the bottom of the part.  I want the hole to be patterned around the perimeter where the spacing will stay around 2" <> even If the size of the sheetmetal part changes...so If width or height of part varies.  I know you can't link to the length of a curve in Inventor so wondering what other options I have.  I don't really want to add a dimension to the 2 vertical sketches as well as the 2 horizontal sketches and then do simple math to round to the nearest integer.
LT.Rusty
You actually *can* link to the length of a curve, but it gets messy and it’s probably not the right way to do things.
Take a look at what I did in the attached file. In the parameters there’s a unit mismatch between inches and unit less, which Inventor resolves as being centimeters, apparently, so I have to divide the curve length by 2.54 to get it back to inches, and then divide that by 2 to get the correct number of holes, which then shows an error due to expecting unit less but finding inches… but it’s not a fatal error, and it will allow you to actually do it.
I tested this part with changing the outside dimensions, and it seems to be fairly robust- I didn’t get any errors beyond the one already described.
Rusty
SBix26
This works great, especially with a few tweaks to equations:
Instead of the "round" function you can use "floor" (round down) or "ceil" (round up), depending on your needs.  You could also add a user parameter for the preferred spacing, to be used in both the holeQuan parameter and Sketch2 (not shown above).
Sam B
Inventor Pro 2025.2.1 | Windows 11 Home 24H2
LT.Rusty
Interesting- adding the round function actually cleans up the unitless error. I didn't realize that would happen.
Yeah, that's a definite improvement.
Rusty
SBix26
No, I changed the units on the "2" from unitless to inches.  The round function requires a unitless argument.
Sam B
