Creative Inventor
Creative Inventor
Message 1 of 11
Creative Inventor
Does anybody have an archive of the Creative Inventor magazines?
i am looking for an article about creating a welding fixture using imported customer parts. I have misplaced my printed copy of this article.
chris
Inv 2018
Replies (10)
Message 2 of 11
Cadmanto
Chris,
Maybe through this link you may be able to contact someone to get archived versions.
https://www.businesswire.com/news/home/20100125005634/en/Tekni-Consulting-Launches-Creative-Inventor...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 11
Frederick_Law
Do that all the time.
Weld fixture and machining fixture.
Anything you want to know?
Message 4 of 11
i need to make a die to form this part, i think i need to use surfaces not sure.  our die will be the same form but the part is not the same profile.
The info in creative inventor showed exactly what i was looking for. surfaces & 3D sketch are my weak spot .
Any help would be appreciated
Chris
INV 2018
Message 5 of 11
i will try and contact them.
Message 6 of 11
Cadmanto
I did see the editor that writes much of that magazine, had a Linked In link if you google search his name.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 7 of 11
JDMather
@Anonymous
Are you still looking for solution to this issue?
Message 8 of 11
JD,
Yes i am , any help would be appreciated..
Chris
Message 9 of 11
JDMather
@Anonymous wrote:
..  our die will be the same form but the part is not the same profile.
I was about to work up an example based your posted file, and then I went back and read this.
What does this mean?  I don't want to chase my tail trying to arrive at a solution.
Message 10 of 11
Frederick_Law
Fixturing and forming are too much different.
What is the material?
You forming from a flat ring?
Are you forming (punch, press, bend) or casting?
Message 11 of 11
Ok,
Here is the flat ring i need to bend,the cross section is different to the sample i first uploaded.
Material :- Aluminum
Chris
