Creating Table of X-Y-Z Coordinates from Point Work Features
**New to Inventor 3D sketching and 3D sketching in general, not new to CAD.**
I have drawn a part using the 3D sketch feature. I need to properly constrain this part in a print now; This is proving too challenging, so I'm here to make sure I'm not trying to do something that doesn't exist.
In a 3D sketch, it's a little more funky than a 2D sketch, sure, but wouldn't you think there are key things to make easy to dimension for telling people how you want the part made reliably?
For instance, this part is a radiator hose. That means it's changing X-Y-Z and thus has center points for each tube bend. It's been FAR TOO CONVOLUTED to make those center-points whether in the ipt or idw world, and I want a table with coordinate locations anyways which is why I am asking about Point Work Features.
I have drawn sketches on both the ipt part, and idw print to try an accomplish what I want as a shortcut first, I also needed the ipt sketch to place the work points.
When I tried this in the idw world, for some reason, a sketch line will remain visible after exiting the sketch in the idw file, but the center point won't??!!
In Sketch
Out of Sketch
As you can see, my layers show that it should show (even though the sketch center-point is different here, so why no layer option?) but nothing is there?!
I really tried work features with more hope of easy success, but they seem useless, with respect to easily accomplishing my end goal like I should be able to in 2018. When you're sketching, you can import a spreadsheet with X-Y-Z points, can I export these work features to do the same? I sure hope that I'm missing it since all the data is literally already there.
However, I've seen these posts and was hoping they weren't serious:
- Extracting x, y, z, coordinates of Inventor model features
- Export 3D Points to Excel Inventor 2016
- Unable to export 3d point co-ordinates data to excel
- Get Coordinates of workpoint using ilogic
Software this price, with the data already present, 15+ iterations from Version 1.0 and I still have to do the work, ugh...am I missing something?
