Hello. I have an assembly with about 13 parts that were CADed in from old drawings in the 70s. The drawings do not have dimensions, and the scans were 300 DPI :-(. As a result, the parts are marginally accurate at best. Here's a picture of the assembly:
As you can see, there are many slots in this assembly, and there is a spar in one of the slots at the bottom.
I need to create 32 of these, and I'm worried about my process. my strategy so far is to use a 3d spline between the slots, and loft a rectangle through the spline. For the purposes of these parts, a rectangle is all the profile needs to be.
Is there a way to create these spars faster? I'm not sure that manually clicking each point is what I want to do 12x32 times.
Here are the givens:
each part has the same number of slots.
each slot may not be coplanar to each other slot that holds a spar.
each slot is rectangular, and have the same dimensions (3/32" wide x 1/4" deep)
each slotted part is currently assembled and grounded.
the slots are not at regular angular intervals, or regular directional intervals, and are off by a percent or 2.
There's no way to get higher resolution scans
Thanks in advance for any wisdom, CADing parts from bad scans with no dimensions is... difficult.
