Creating solid from imported .SAT file
NigelHay
Advisor Advisor
Message 1 of 14
NigelHay
I have a part that I have extracted from an imported .SAT file. The surfaces are mesh-like but not recognised as meshes in Inventor. I've tried to use the various mesh tools to make this part solid so that I can incorporate it into my assembly but nothing has worked so far. The surfaces seem to be made from lots of discrete triangles, is there anything I can do to make this a usable part?
Inv2020
Win10 pro
Replies (13)
Message 2 of 14
JDMather
Looks like converted stl, but in  any case - it opens fine as a solid body for me?
Given that the geometry is so simple - I would simply remodel from scratch without the stl facets.
Message 3 of 14
NigelHay
JD, thanks for your reply. I can open the part as well but not do anything with it. Inv will not recognise any faces to start a sketch or let me manipulate it &, when I place it in a drawing, I can't pick up edges etc. to dimension sensibly. The block is simple enough but the curved cut-out in the front is not regular & is asymmetric about both axes, not easy to reproduce.
Message 4 of 14
JDMather
Everything works as I would expect on my machine.
Can you create a Screencast Recording?
Message 5 of 14
NigelHay
I had to install & quickly learn screencast. The clip shows how I am unable to select faces or edges to work with.
Message 6 of 14
JDMather
Try posting link rather than embedding.
Message 7 of 14
NigelHay
Is this better?
https://autode.sk/3jSBNcM
Message 8 of 14
JDMather
Everything looked normal to me in your video.
I can't really tell, but it doesn't appear to me that you ever clicked your mouse button to select anything?
Also, it would probably be more useful if you turned on edge display.
Message 9 of 14
NigelHay
That's the problem, I can't select anything. All of the surfaces are divided into small triangular facets & all of the edges are segmented.
Message 10 of 14
JDMather
I will post a video when it is done compiling.
I do not see anything unusual.
Message 11 of 14
johnsonshiue
Hi Nigel,
I believe the body came from promoted mesh from Inventor Shape Generator. It was a mesh. Then it was exported or promoted to Part environment. Then use Mesh Enabler to convert it to a solid body.
I don't think such geometry is directly useful for design. You should recreate it from scratch using properly constrained sketches and features with high precision. Then the geometry can be properly dimensioned.
Many thanks!
Software Test Engineer
Message 12 of 14
NigelHay
Message 13 of 14
JDMather
I had no trouble picking vertices, edges, faces - as you stated in problem descriptions.
I think the issue is the source geometry - before you ever get to Inventor.
A better stl source might be useable.
Message 14 of 14
NigelHay
JD, I think you are right. I received today a STEP file of the same object but, although it is smoother, it suffers from the same problem. I'll have to see if the originator can export it in a more user friendly way.
