When I create a PDF directly in Inventor, it brings all the layer info in as well on the left hand side of the screen. Is there anyway to avoid this?
Solved by blair. Go to Solution.
You can minimize the side panel. I would think that you would end up having a Style with everything on a single layer. Not sure that you can set that up in Inventor Style Manager for your drawing file.
The simplest would be to get a 3rd party PDF printer such at PDF995 or other software if you don't want to purchase the more expensive Adobe Acrobat. Although, for doing drawing packages, the Adobe Acrobat does allow you to combine single PDF files into one PDF file and organize them in what ever page numbering you wish.
yep.. need to install a PDF "printer" to be able to control that (or not show layers)..
I use Adobe acrobat but cutepdf or other like blair suggested will accomplish your goal.
