- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Beginner AutoDesk user here.
In class we were tasked with recreating a lego piece in Inventor to be 3d printed as a test for whether the 3d drawing was accurate. My drawing is attached. However, I have encountered a few problems that neither I nor my teacher know how to circumvent.
1) The cross-shaped pattern near the top of the piece needs to be attached to the hourglass shape directly below it, and that whole pattern needs to go completely through the piece. I tried creating a hole but it wouldn't let me select that particular shape, and I have had no luck merging the lines of the two shapes together to create a contiguous shape.
2) I used a rectangle pattern on the first hourglass shape that I created and extruded down less than a mm to copy it up the front face of the Lego piece. I need to add one more hourglass shape between the two bottom holes that has the same dimensions as the first three but is rotated 90 degrees. I will also need to recreate them on the opposite face of the piece, in the same positions. Is there any pattern I can use to rotate and copy the hourglass shape, or is there a simple copy/paste function that I am unaware of?
Thank you in advance!
