Creating multiple folds on 1 face
Message 1 of 24
I am trying to make a sheet metal part that has flanges folded down on one side and then folds running orthogonal to those flanges to make a somewhat curved have tunnel if you will. See model. Inventor 2018 won't let me make the folds on the face I previously folded the flanges from. What should I do?
Replies (23)
Message 21 of 24
JDMather
Are you checking the dimensions as you go?
Also, where are you getting the information for Thickness and Bend Radius?
Message 22 of 24
Thanks again for your sensed and constructive answer,
i understand my fault about the dimensions
i had not checked the dimensions after made the flange cause i thought them come up right,
now i'm  understanding also  the tickness has to be considered carefully,
i would like to know how you choose the thikness of 5 mm and radius ?
because i don't really know where i can get it or how i can understand this 2  parameters
indeed to me it seems like a math issiue also missing knowledge
Message 23 of 24
JDMather
I dimensioned the sketch of your original file.
It is common to use a Bend Radius equal to Thickness.
Message 24 of 24
Thanks for your reply
