Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
I'm tending to agree with @JDMather, if you can share what are you trying to accomplish that would be helpful in directing the best way of modeling.
Do you have part specs or dimensions you are trying to reach?
Here's a screencast going through a few helpful tips:
If you want to make the angled gap flush/parallel to each other you have to do additional calculations to get it to match up but not sure what your intent is.
At 3:30 you could project the horizontal line from Sketch1 and use Collinear Constraint to it instead of creating the Cut_Rad dimension reference.
Also noticed you projected the X and Z axis for alignment, a better approach would be to just Project Geometry > Center Point and use Coincident Constraint to it and make the lines horizontal and vertical instead. That way there is less overlapping of lines requiring RMB > select other... if you ever want to select them.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
