Announcements
Creating iLogic for empty fields in iproperties
Hello All,
I would like to create an iLogic rule that would remind me that certain fields in iproperties are currently are empty, particularly the "project" field.  This rule should work for .ipt, .iam and .idw.  Just a heads up that I am clueless or know very little about creating iLogic so if you can walk me through this it would be appreciated.  Many thanks in advance.
Patrick
Sergio.D.Suárez
Dim doc = ThisDoc.Document
Dim oProject As String = doc.PropertySets.Item("Design Tracking Properties").Item("Project").Value
Dim oDescription As String = doc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
Dim oRevision As String = doc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
If oProject = "" Then MessageBox.Show("Project is empty", "Ilogic")
If oDescription = "" Then MessageBox.Show("Description is empty", "Ilogic")
If oRevision = "" Then MessageBox.Show("Revision is empty", "Ilogic")
You can add events to the ilogic rule to run automatically before saving the document and warn you that it has empty fields
See the following link for more information
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you so much, your iLogic rule works beautifly.
Sergio.D.Suárez
I hope that I have served you the solution, If so it was please mark it as accepted, greetings
Mechanical Designer
