Creating an audio jack.
Message 1 of 8
 I am looking for an advice, how to create the "cuts" at the audio jack rubber part (highlighted at the picture). The problem for me is that the part is created as a loft (cuz it needs an angle at my case) .. see the inventor 2014 part attached.
Replies (7)
Message 2 of 8
I would do a square profile with a partial revolve, then mirror, for the parts that are missing material on the 'L' jack. Say from -15 to 15 degrees.
Message 3 of 8
See example.
Message 4 of 8
Hey Robert
I am not sure i follow you. I can't figure out how to do the sketch on a loft.
The revolve example does not opens (error in reading RSe)
Message 5 of 8
Neil_Cross
If you're using Inventor 2014, chances are most people will upload a file for you done in 2015 which you won't be able to open.  That's the message you get when you try and open a file done in a later version of Inventor.
I was gonna give this a pop but I only have Inventor 2015 too, so you wouldn't be able to open anything I upload.
Message 6 of 8
Neil_Cross
This should do? There's probably a more efficient way of doing this but it's a quick job and get's the desired visible effect.  All sketches and features are adaptive to a certain extent, but that part could be better if anyone is to open this up and poke holes at it! It was a 5 minute job after all Smiley LOL The file is attached, but it's 2015 format so I'm afraid the OP may not be able to open it.
Message 7 of 8
Thanks ! Just got it to work, and then saw your post =))
Message 8 of 8
Neil_Cross
No probs Smiley Happy  I was considering going down the plastic part route and using the grill function, but an patterned extrusion seems to be just fine and a lot quicker as long as the extrusion profile doesn't clip the surrounding faces.
