I am experimenting with new modelling methods,
as opposed to modelling each part and assembling via constraints
I have found the create components button that allows me to create an assembly of multipme components from a single multi body part.
So I model an assembly as one part but multi body
then create the assembly and its parts at the end by this feature.
The downfall is that if I have multiple parts that are the same,
I cannot find a way to make it recognise this and instead of creating 4 different parts for it to make just 1 in 4 positions for example.
If anyone knows an efficient way of doing this that would be much appreciated.
I have also seen the create layout tab, but I have not used this before.
Maybe I would be better using this?
I really like how easy it is to create associativity when everything is modelled in one part you don't have to project, copy geometry or share expressions for example, this is all much easier working in just one part. And when you do create the assembly all components are grounded at the origin but automatically in the position they were in the original part. So it saves me using constraints.
The way I am doing it at the moment to solve my problem is to create just 1 of the components if I have several the same. Then pattern or copy it once I get into the final assembly. But it feels like I am doing the same work twice.
Please if someone can help me, or maybe direct me if they have experience, is the create layout function a better way to achieve what I am trying to do, I understand you can make blocks and things in there. I watched some videos on it a while back, but also seems like I'm very close to achieving what I want in the method I am currently using also. Much appreciated if anyone can advise here.
