I'm new here to the forum.
My company just started using Inventor.
We transfer from Siemens NX.
I have a few questions, will post them all as separate topics.
One problem we are having is the copy geometry function.
It seems like I cannot copy geometry as a solid body and have the option for it to be associative
I can copy it as a surface or composite and it will allow me to tick associative
But when I click to be solid the option for associative disappears.
Is this just not possible in inventor?
I can still work like this for what I need to do, but I would prefer just to copy solid if possible for then using the combine function to join or cut out the copied geometry. Instead I currently copy as a surface then use the sculpt.
There also seems to be output options when using copy geometry.
1 method create object that works like I say
the second method join to existing doesn't appear to work for me either
when I select 'join to existing' method it allows me to select the input geometry
but it does not allow me to select the output geometry 'existing'
The way I assume this should work is you are in an assembly for example and want to join one part to another to make all thew same part. I activate the part I want to keep and go to copy geometry, method join to existing, select the other part as input geometry and in output geometry select the active part that I want to join it to.
I am open to suggestions as to other ways to achieve what I am trying to do,
I want to join one part to another or take away one part from another.
My company use joining features for sheet metal.
we bring in the standard joining feature which has a male and female body
we add the male body to one part, and subtract the female from the other and this allows you to join 2 plates for example.
