- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to create a nest for a complex bracket out of a block of plastic. I have attached a picture to show how the bracket sits in the block.
What I have done so far it make my block (solid) and place my bracket (surfaces) inside of the block where I want it. What I need to do is cut out the block where the bracket sits. Most of the bracket is below the surface of the block, so I need to blow it all the way out the top. In the assembly, I editted my block and copied the surfaces of the bracket into the block. I tried using the sculpt command but it produces an error. I think this is because my bracket is actually inside my block. Does anyone know any tricks to make this do what I want.
I'm using Inventor 2015.
Crev64
