Creating a Global Ilogic rule to update rules and drawing resources from template.
frank.blom
frank.blom
In my template i have several rules to save drawing as pdf/dwg with approval state or approved state.
(also centering dimensions, and removing loose centers and dim)
These are easy accessibele through a form with buttons.
I would like to use them in older drawings (because they get copied), but i dont know how to add rules to existing drawings with a push of the button.
Also i would like to update the drawing resources, sketch symbols, title blocks and borders.
japike
We use mostly external rules so, I'm not sure how to transfer rules but, you can use the Drawing Resource Transfer Wizard to copy drawing resources. Click on the windows start button and look in the Inventor folder.
Peace,
Jeff
Inventor 2024
Alexander_Chernikov
You can first export the desired rule from the iLogic editor
and then add it to external rules tab
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
frank.blom
Thanks.
I will try the drawing recource transfer utility.
Recently (1 year ago) i switched to external/global rules, but the old drawings get copied a lot.
So i dont get rid of the old in document rules.
Thanks Japike & Alexander
Br,
Frank
