Creating a flat or 2D spiral sweep path
Barry1Lau
Barry1Lau
Inventor 2020
I'm trying to create a flat spiral sweep path on a surface with a 1/2" offset between turns to cut a groove in a plate.  The coil function is close but I don't need the vertical portion.
JDMather
Can you Attach the *.ipt file of your "close, but not quite" attempt?
Barry1Lau
Here are 2 ways that I tried to work this problem.
JDMather
Before I spend time on this - are you aware of the Spiral Type of Coil?
Barry1Lau
I could not find this function or instructions on how to do it.
Barry
JDMather
See Attached.
Barry1Lau
I found the answer in another post. Thanks for the help.
Barry
