I have a design problem where I need to reverse engineer a fairly complex tank structure.
My idea of workflow was to:
make a preliminary design of the tank (part to the left).
Identify the top of the tank in the point cloud (marked assemble work plane).
Identify the rotation axis of the cylindrical point cloud tank.
Place tank acc. to plane and axis and rotate tank into a certain position and lock it and finish the design.
I have identified the center in the point cloud with a simple assembly sketch which I intend to use to make an axis through this point and normal to the work plane.
Problem here:
I want to create a work point in the center of the sketch circle in order to create the axis, but the "point - On sketch point" command DOES NOT WORK. I can not select the points in the sketch..
Note all object visibility is on.
What am I missing here?
