GT2 profile
It is 2020. I am using Inventor 2018. What I want is very simple: I want a profile for a 60-tooth GT2 pulley. It ain't rocket science. The instructions for how to draw this from scratch are cumbersome. I should be able to go to a design tab, say "GT2 profile", give a number of teeth, and have it give me a profile. I can then bind the center point of this profile to where I want the center point of the pulley, and that should be all that I need.
I have found GCODE files that pretend to do this, but they have absurd restrictions. For example, they assume that I want a 5mm or 8mm shaft, and a #4, #6, or M3 set screw. No, today I need a 60-tooth pulley with a 22mm shaft and three #6-32 set screws at 120 degree angles. I need another gear two projections that activate microswitches to limit the travel. Without a complete rewrite of the GCODE, I have no hope of getting what I need.
It is complicated by the fact that it takes 2.24 revolutions to cover the range I need, and to put the microswitches in, I need to go some odd gear ratios so that the third gear travels less than one revolution between the two microswitches. This is my job. The job of the tool is to create what I need. I need to connect a continuous belt of a certain length so I need to model how this belt fits so I can position the shafts properly, and the idlers and tensioners appropriately. Yet I don't see an easy way to do this.
Creating a GT2 pulley profile should take perhaps four mouse clicks and a couple keystrokes:
Create pulley (1 click)
GT2 (1 click)
60 (1 click and two keystrokes)
OK (1 click)
Now I can extrude this profile to get a gear as wide as I need; I can then create another profile so I have two belts on one pulley; I can put a 22mm shaft hole in place with another extrusion. I can place set screws where I want them. They can be whatever size I want. I can use the setscrew drawings from McMaster-Carr. But I can't see why I can't create any gear I want, down to 2mm shaft diameter, worm gear, bevel gear, whatever I feel like. Why are there so many missing features and absurd limitations in a fundamental tool?
Also notice that if I want a 57-tooth gear, or a 49-tooth gear, or any other tooth count I want (117; 243; etc.) that I can get it, and not be restricted to somebody's limited imagination of 12, 20, 36, 60, or similar silly limits. That's why we have 3D printers, so we are not limited by preconceived notions of what is appropriate. I can build whatever I want for my purposes. It is not the job of the tool to tell me what I can do; it is the job of the tool to take my specifications and create what I asked for.
