Create Parameters in Assembly with iLogic Rule
I have one iLogic Rule which goes through every part in an assembly, extracts info, creates dxfs and exports BOMs along with other tasks
I am missing one element. I need to be able to create parameters in the subparts. I am able to create iProperties, but have not found anywhere how to create a new parameter in a subpart of the assembly in which the rule is running. Right now if those parameters are missing, I am using a Try - Catch to skip over tasks that would fail if they weren't present.
Any help is greatly appreciated.
Curtis_Waguespack
Hi heather5UNX9,
Something like this should work.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Sub Main
	Dim oValue As Double
	dValue = 15 'value to push to each component
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
    ' Iterate through all of the referenced documents
    Dim doc As Document
    For Each doc In asmDoc.AllReferencedDocuments
        'update the components
        Call UpdateParameter(doc, dValue)
    Next
End Sub
Sub UpdateParameter(oDoc As Document, dValue As Double)
    ' Get the user parameters collection.
    Dim userParams As UserParameters
    userParams = _
   	oDoc.ComponentDefinition.Parameters.UserParameters
    Dim param As Parameter
    'set/create parameter
	Try
   	param = userParams.Item("TestParameter")
	param.Value = dValue
	Catch
   'The parameter doesn't exist so add it.
    param = userParams.AddByExpression("TestParameter", _
   	dValue, UnitsTypeEnum.kDefaultDisplayLengthUnits)
    End Try
End Sub
Thanks for the great help.
