Create New File
Create New File
Message 1 of 13
Create New File
You can see this template is saying “Drawing - Create an annotated document”. I wish to know whether you can insert your own template. If so please show me the procedure.
Replies (12)
Message 2 of 13
mdavis22569
Yes you can .... I have quite a few
2d IDW's and pre set up 3d files
There are a few ways ...
1) save it to the template folder location.
2) if you go to your save copy as ...you'll see a save as template option too
Mike Davis
Message 3 of 13
I am able to insert my template in INVENTOR. You can see I must give a location as well.
Save in where?
Message 4 of 13
mdavis22569
there are saved where you set up them in your application options
Mike Davis
Message 5 of 13
My template is in Desktop and file name Asheet. I gave following file path but it is not saved in Create New File window of the Inventor.
C:\Users\Maha\Desktop\Asheet
Message 6 of 13
mcgyvr
Thats the "Undo" location.. (read the field titles)
Look at the field below that.. Your templates are stored in your "documents/autodesk/inventor 2015/templates" folder
Message 7 of 13
What I want to know is while retaining the standard templates whether it is possible to add my own drawing templates.
Message 8 of 13
blair
Yes but you need to use the Save As Template option, this will place it into your Template Folder. This location is controlled by your Application Options
http://autode.sk/1Urro8b
Delta Tau Chi ΔΤΧ
Message 9 of 13
mcgyvr
You can also just look right at the top of the new file dialog to see where your templates are located.
Thats where you need to save any new templates..
Message 10 of 13
What I want to know is while retaining the standard templates whether it is possible to add my own drawing template which is on the desktop.
Message 11 of 13
blair
Why would you want to do something like that. Each time you click on the template it will open another instance of Inventor. Forget the Desktop!!!!!
1.) OPEN INVENTOR FROM THE ICON
2.) MAKE SURE THAT YOUR PROJECT FILE IS CORRECT
3.) OPEN YOUR FILES THROUGH INVENTOR, EITHER EXISTING OR START NEW!
Delta Tau Chi ΔΤΧ
Message 12 of 13
mdavis22569
As I said earlier ...YES YOU CAN  ... you can save them to the template folder like we've all been explaining.  I have several types of each depending on what I'm doing. I have premade templates for angles, roud bar etc ...
Mike Davis
Message 13 of 13
Before it didn't, now it is coming. Thank you for your explanation.
