Create Linear Slides with the Linear Movement
Message 1 of 16
I want to assemble a Actobotics Xrail Linear Slide kit (aluminum extrusions) in Inventor and show the linear movement
hqdefault81AUomOReDL._SL1500_637212_rev1
Replies (15)
Message 2 of 16
JDMather
Attach your assembly here.
Can you  explain the issue in more detail?
Message 3 of 16
mcgyvr
Simply create appropriate constraints and use constrain limits where needed to allow the slides to move as needed..
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
First video I found.. https://www.youtube.com/watch?v=ifIDI2nb7JQ plenty more by simply searching for "Autodesk Inventor constraint limits"
Message 4 of 16
johnsonshiue
Hi! If I understood request correctly, this could be done in Inventor Studio or simply use Drive constraint to animate the movement. Or, you can create a presentation animation.
Many thanks!
Software Test Engineer
Message 5 of 16
What constraint would you use to allow for the sliding movement?
Message 6 of 16
JDMather
I would use Mate.
Message 7 of 16
https://www.servocity.com/media/attachment/file/6/3/637212_assembly.zip
This is the step file that I'm working with
Message 8 of 16
I am trying to mate the roller to the inside of the extrusions and create the limits but can't.
Message 9 of 16
JDMather
Attach file here, not 3rd party site.
Message 10 of 16
Here's the file from my computer locally please send it back if you can help me out. Thanks!
Message 11 of 16
mcgyvr
Quick attempt to get you started is attached..
Message 12 of 16
JDMather
You Attach a STEP file, not Inventor assembly.
Attach your attempt to add the necessary assembly constraints.
Also, indicate what version of Inventor you are using.
This one will be an easy problem to solve.
Message 13 of 16
I am using Inventor Pro 2019. On a side note is this possible in Fusion 360. Thanks again!
Message 14 of 16
Thanks for the help, but one problem I encountered when opening up the file you attached is that is say Inventor 2019 can't open a newer file.
Message 15 of 16
JDMather
You should always state what version of Inventor you are using - especially when it isn't the latest version.
Drag the attached assembly.  This motion can be driven if desired.  Keep the assembly constraints simple and robust.
Message 16 of 16
Thanks for the feedback, I really appreciate your help this is going to help my Middle/High School FTC Robotics team alot.
