Announcements
Half-section view - AS1100 Standard
Hi all,
I have a question about how to do the half-section view in accordance with the AS1100. In this standard, we have to change the half-section line to a full section line. This is the way I have been taught:
Is there another way of changing the half-section line to a full without having the extra sectioned view at the bottom of the drawing sheet?
Thanks all.
jhackney1972
The process is a bit convoluted but it can be done.  I cannot explain why the Crop box shows, even after I edit the drawing browser entry to tell it not to, but you see I can get it to update by toggling the Edit command.  Of course if you want the half section on the opposite side, just select different points.  I read up on AS1100 Standards and could not find anything about this practice so be sure you want to use it.  Take a look at my Screencast for the process.
John Hackney, Retired
Oh my God... Thank you so much for replying and making a small video. Yes, your video helped me out a lot. Cheers!
