create exploded views
niall.rasmussen
Message 1 of 16
niall.rasmussen
What details or information is needed to create an exploded assembly?
Can you explode a 3D model file?
I have a 3D model file and would like to know if it can be exploded within a software or will you need all the source files that created this model file?
Any advice or reference will be appreciated.
Niall
Replies (15)
Message 2 of 16
l.oostewechel
You need to have a assembly. Dont know if a multi-body part works.
Message 3 of 16
CCarreiras
Hi!
You can explode a file assembly, but you must have all the files that are present in the assembly also available.
Open your assembly, and if it is all good (no missing parts), just click: Create Presentation
CCarreiras
Message 4 of 16
kacper.suchomski
In a multi-body part file, you can create a new Model State by moving the bodies using the Direct Edit tool.
Kacper Suchomski
Message 5 of 16
niall.rasmussen
Thanks CCarreiras,
Yes my sample file is only a single body part file assembly with no access to part files which means I cannot do anything.
Niall
Message 6 of 16
CCarreiras
If your model is a multi solid, you can turn each solid into a part, and transform it in an assembly automatically:
Then, you can explode the model.
Use this tool:
If your model is only a body, you can try to separate first in several bodies and then use the "Make Components " to create the assembly.
...depends on the model. If you share more info , or the model itself , we can help more.
CCarreiras
Message 7 of 16
niall.rasmussen
Hi CCarreiras,
I have attached a file of the model in a pdf format, which I also have as a.dwg file. The image is of an exploded assembly, but I cannot explode it myself only view it as it is.
Niall
Message 8 of 16
CCarreiras
But .... you don't have the 3D model?!
CCarreiras
Message 9 of 16
niall.rasmussen
Yes, the previous file was the first example I have. I guess that format is not usable.
I have attached the next sample. Hopefully you will be able to open it.
Regards
Niall
Message 10 of 16
CCarreiras
Sorry, Inventor doesnt open such kind of Rhino format files.
CCarreiras
Message 11 of 16
niall.rasmussen
Hi CCarreiras,
I open this file with Autodesk Viewer, maybe you can try this and see what options may be possible for this file.
Regards
Niall
Message 12 of 16
niall.rasmussen
Hi CCarreiras,
Were you able to view that file through Autodesk Viewer?
Just curious to know what your advice or suggestions on this model would be in regards to creating an exploded view of same.
Regards
Niall
Message 13 of 16
kacper.suchomski
Think of Autodesk Viewer as a PDF viewer.
Kacper Suchomski
Message 14 of 16
niall.rasmussen
https://help.autodesk.com/view/ADSKVIEWER/ENU/?guid=ADSKVIEWER_Help_SupportedFileTypes_html
I am able to open this .3DM file with Autodesk Viewer, maybe you can try this and see what options may be possible for this file in regards to creating an exploded view of this 3D model.
Regards
Niall
Message 15 of 16
CCarreiras
Hi!
Your model is made of meshes. Meshes is a kind of surface web... kind of a shell.
To create explosions, you will need to have solids.
You can turn meshes into surfaces, and surfaces into solids (Adding thickness to the surfaces or other methods, depends on the part), but in this case you will need weeks to do that to all model surfaces.
sorry, but...
Without solids, you cannot  explode the model with Inventor or any similar solid modeler (and i don't know if exist any software to do that with meshes).
---The alternative is export this model in "solid mode" from Rhino.
CCarreiras
Message 16 of 16
niall.rasmussen
Thank you very much CCarreiras for your insight and advice. I understand a bit more now about exploded views and its requirements. I know I was clutching at straws with my examples, but I do understand what information you really need to create a practical exploded view.
Thanks again for your time and expertise.
Regards
Niall
