Perpendicular Cut Following a Curved Path – Any Direct Method?
a.brusamolino
a.brusamolino
Hi everyone!
I need to make a perpendicular cut on a rolled sheet, as shown in the figure, meaning I have to cut the lower circle following the curved path. Is there a command similar to "sweep" as in the "3D model" environment? Or is this a feature added in newer versions? I'm using version 2023.5.1, and I can't find anything that helps.
Since I need to create a jig to print and wrap around the outer diameter of the tube, my current workaround is to reduce the thickness to 0.1mm, perform the sweep, and then flatten the model (since the sweep it's not a true perpendicular cut, the 0.1mm thickness helps minimize the "double edge" effect). This method works for my needs, but I was wondering if there's a way to do this directly in the "Sheet Metal" environment without having to reduce the thickness every time. Small thicknesses are negligible, but with larger ones, this wouldn’t be accurate.
Thanks to anyone who can help!
Replies (7)
YannickEnrico
Either start with a surface and use thicken, or sweep along the path, and use thicken intersect to transform the solid to one with perpendicular cuts
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
JDMather
@a.brusamolino wrote:
This method works for my needs...
I think I know what you mean and I think there is a correct solution, but to be sure I understand the Design Intent, can you Attach a file that illustrates your work-around technique.
a.brusamolino
Hi @YannickEnrico ! Thanks for the suggestion.
I tried using the Thicken Intersect command after the sweep, but it doesn't produce a perpendicular cut. When I flatten it, I can still see the double edge.
I'm attaching the file.
a.brusamolino
Hi @JDMather! Of course, I'm attaching the file.
You can find the workaround in the model state "DIMA". I created the model state because, in the assembly where it's inserted, I want the tube to remain without the sheet metal separation line.
kacper.suchomski
Hi
  1. For a flat pattern it is necessary to correctly define the sheet metal settings - the defined thickness must be the same as the thickness in the model
  2. If you need a flat pattern for a 2D machine, you will additionally need to create perpendicularity of the peripheral surfaces.
ScreenRecorderProject712.mp4
Video Player is loading.
Current Time 0:00
Duration 1:44
Loaded: 9.45%
Stream Type LIVE
Remaining Time 1:44
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Kacper Suchomski
    YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
    a.brusamolino
    Thanks a lot for your reply @kacper.suchomski !
    Ok, this is basically the same approach as @YannickEnrico mentioned, but applied to both surfaces, internal and external. And it works for me.
    So, in the end, we can say that there isn’t a dedicated command for making a perpendicular cut along a curved path, just different workarounds to mimic it.
    It would be great to have this included as an improvement for the Cut command.
    However, with this method, at least the thickness is preserved. Thanks a lot!
    (PS: Regarding the sheet metal thickness, it was set to 0.1 because it referenced the other model state, the "thinned" one, which I associated with the flat model for printing.)
    kacper.suchomski
    The cut command has a perpendicular mode.
    But here we have a different goal - matching geometry.
    And for such scenarios double intersection is dedicated - this is the standard scenario.
    Kacper Suchomski
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
