We have an issue Vault hanging on creating DWF file through the job processor, but it seems not a Vault related problem, as we can not create DWF neither using Inventor. It just hangs. Anyone an idea what could be the issue?
Solved by johnsonshiue. Go to Solution.
@johan.degreef
Hi Johan. Do you have Autodesk Design Review installed on your machine? And, if not, is this box checked when you try to Save as DWF?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
No, it does not need to be checked. If ADR is NOT installed, and that box is checked, it would explain the problem.... but it looks like this is not the cause.
Chris Benner
I checked with a colluege, and it hangs on his computer too.
By accident I found the problem. It was 1 part in the assembly that made it un-DWF-worhty. Don't know what's wrong with it, but when removing it, the export to dwf works just fine.
@johan.degreef
Looks like @johnsonshiue provided a solution on this thread. Fingers crossed!
Chris Benner
Hi Johan,
To save you a few clicks, here is the file. Basically, the thread faces are the problem. Inventor has trouble exporting them properly. Removing the faces makes it work. Please see attached file.
Many thanks!
