Create angle against ax
Hi, I'm trying to create an angle between the purple circle center point and the ax without drawing a line on the ax.
gcoombridge
You can't have an angle between points. If you pattern sketch points (assuming you are doing some kind of flange), you can add a horizontal constraint between the top two. Screenshot below
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Cris-Ideas
Why you do not want to draw a line?
It is the simplest method. and line does not need to be long, it can be so short that you will barely see it.
Alternatively you can define your angle as a parameter and than use two orthogonal dimensions of proper trigonometry functions (sin, cos) of your radius.
But I would really go with the simplest option, that is a construction line.
Cris
Cris,
https://simply.engineering
tyas.swinnen
With current Inventor versions you can draw an angle between 3 points...
I've added a youtube link with a visual example of how to achieve this 🙂
https://www.youtube.com/watch?v=f19KOHNvPB0
JDMather
@Anonymous
Attach your file here if you can't figure it out.
The forum is currently broken - you have Reply-Post-Edit Reply to gain access to Attach.
