Create an actual thread
pomdave
pomdave
Hi All,
Oldie here who retired some years ago.
I have my own copy of Inventor 2011 which I use for making odd items for my model railway using various 3d printers.
That explanation on me done, what I want to do is make a few nuts/bolts on my 3d printers but can't work out how to have a thread cut in a particular item. Is there a way to do this.
Best Rgds
Dave R.
kacper.suchomski
Hi
Use the coil tool.
Kacper Suchomski
pcrawley
There used to be an app for that: threadModeler | Inventor | Autodesk App Store
But they discontinued it on Inventor 2020.  (You might be lucky running it on 2021)
There's now an online version: Home - threadModelerOnline
(If it is just hobby stuff, then you could use Fusion because it models the 3d thread.)
Peter
kacper.suchomski
@pomdave  mentioned that he uses the 2011 version.
Kacper Suchomski
WHolzwarth
Nuts and bolts for model railways? Which sizes?
Even if modeling them is no problem, 3D-printing can be.
It depends on filament, printer settings, nozzle size. I normally print threads with standard settings, and do a final cut with thread cutting tools.
Walter Holzwarth
pomdave
Didn't think about using the coil idea. Had a bit of trouble getting the coil drawing right, but finally got there, thanks.
Best Rgds,
Dave R.
pomdave
Yeah, really big trains.  No, seriously what I was after was a cap style nut to go over the ends of silicon and glue tubes to save wasting the nozzles and getting them clogged up.
Best Rgds,
Dave R
