Create a default title block on drawing (DWG)
richardkurniawan098
richardkurniawan098
Hi guys, good day to you..
my name is richard and im beginner at inventor. i want to ask how can i create a default title block on Drawings (.dwg)?? so i can use it everytime i create a new DWG. i have attached my DWG templates that i have made.
Accepted solutions (3)
Hubert_Los
Add your TitleBlock to empty drawing, and then "Save Copy as Template".
Then you will be able to open the template with its own title block.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
NigelHay
You need to open your title block in Inventor then 'save as' to overwrite the Inventor standard title block.
The path is c://users/public/public documents/autodesk/inventor (your version)/templates/en-US/standard.
rhasell
You can put your template into a template directory of your choosing.
Refer to the application options to find the default template directory.
This can also be configured in the Project options, which will override the application options.
Hint:
If you name the template as "Standard.dwg" or equivalent (iam, ipt, idw etc) The quick "New" selection will automatically load the template.
Reg
2026.3
richardkurniawan098
ahhh i see. this would be very helpful. thanks a lot !!
