Create a custom mold plate and insert into the Mold Base
Hello everyone
I'm trying to create a custom "Bottom Clamping Plate", I can add it to the Content Center but I can not use it when I use the "Mold Base" command with the customize option, the inventor does not allow selecting a custom board.
At first I thought it might be some problem I had created, so I started to create a copy of an existing standard, but the problem still persists. See the Screencast for more information.
Does anyone know how I can work around this problem?
Is it possible to create a Mold Base from the beginning?
I know there is a "User Mold Base" option, but I need this mold to be in the content center.
see the Screencast for more information.
Best Regards
Jorge Luís de Andrade
Steven_Gao
Hello jorge-andrade,
This is a limitation and Mold cannot recognize the content outside from Mold libraries. We authored the components with some special attributes on some geometries. If you want the mold base in content center and create it from beginning, you still need to use the plates from mold libraries.
Here is the help document about Customize Mold Base:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-953691B7-2A2C-473B-88C9-11C9130ED9B2
Steven
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
