- Mute
- Permalink
- Report
I am currently facing an issue with Inventor. I am somewhat new to inventor I used to use it long ago but we are talking decades at this point. I currently use Fusion 360 for my business and I am having issues with it being extremely slow on huge assemblies, so I am trying to give Inventor a shot to see if it will better handle my project and oh boy Inventor's sheet metal tools are so much better than what I have in fusion this alone might push me to switch.
I am having 2 really weird export issues that will not go away even on reinstall. This happens with all exports it seems, I have modeled a very simple and clean sheet metal part for this test. 1 contour flange, 1 cut, 1 corner chamfer.
I then Export this as a Step file. This is where issue one happens. When on the Export dialogue if I scroll through the names and quickly select anything, it takes about 3 seconds for the name file format to update and a few times I accidentally export during this time causing the whole program to crash as its trying to export another format as the default .dwg. So if I have not saved anything in that window is sent to oblivion (I know I don't have much patience its more of a habit exporting quickly than me trying to rush).
And issue 2 happens very often where specifically the Step export can hang for ages, it does not crash but freezes the window for a very long time, I have to force close the instance in task manager. This does not always happen and once I did leave it for a long time and it exported but the step was somewhat corrupted.
I assume at least the 2nd issue is either because I have OBJ 3d scans in the ipt file or and issue with the translator as for issue 1st I am not sure if this is normal.
Can anyone advise if I have a corrupted install or any steps to try update or fix this issues? I am on Build 298 2026.2
