Inventor Forum
Crash opening files
5 REPLIES 5
251 Views, 5 Replies
Crash opening files
Version 2019 crashes when opening or creating files (parts, assemblies). Starts loading (status bar says "loading..."). Then app closes. Shows up as an "error" event in Windows 10 log.
5 REPLIES 5
JDMather
More information is needed.
1.  Did it used to work and now it doesn't or did it never work at all?
2. Have you installed the Updates for 2019?
3. Have run the Inventor Reset Utility?
4. Have you rebooted the computer and the behavior persists?
5. What are your system specs?
in reply to: JDMather
1.  Did it used to work and now it doesn't or did it never work at all? Just Failed today. Worked well before.
2. Have you installed the Updates for 2019? No. Where do I get them?
3. Have run the Inventor Reset Utility? No
4. Have you rebooted the computer and the behavior persists? Yes
Dell Precision 7530
64 Bit
Windows 10 Pro v 1903
OS Build 18362.295
Not sure what else you need.
Ran utility - no help
JDMather
2. Http://manage.autodesk.com
johnsonshiue
Hi! A few things to try. Please install 2019.4 update followed by 2019.4.1 update. Make sure graphics driver is up-to-date.
Many thanks!
Software Test Engineer
Technology Administrators
