Crash during a MEP connector adding for a Subsitute Model State
Artem_Marinin
Artem_Marinin
Hi all!
I created a Subsitute Model State of an assembly by Symplify function. Now I want to add a Pipe Connector by Environments tab -> BIM Content. I can set position and parameters for the connector, but I when I click OK or Apply in the Pipe Connector window, Inventor crashes. Is it a bug or I do something wrong?
Inventor Professional 2023.2.1.
Any help will be appreciated!
Best Regards,
Artem Marinin
johnsonshiue
Hi Artem,
This is definitely a bug. If you can reproduce it, please share the files in zip with me directly johnson.shiue@autodesk.com. I would like to understand the substitute workflow crash better.
Many thanks!
Software Test Engineer
Artem_Marinin
Hi @johnsonshiue ,
I sent an email to you.
Thank you!
Best Regards,
Artem Marinin
johnsonshiue
Hi Folks,
Just to provide some update on this issue, it seems to be related to a substitute subassembly. Somehow, the BIM Content process chokes on it. I am working with the project team to understand the issue better.
Many thanks!
Artem_Marinin
Hi there!
I know that Inventor project team is working on this issue, but maybe some extra info will be useful for somebody.
I did some research and what I found:
1. If I try to add a pipe connector for any substitute based on any model state, Inventor crashes.
2. If I try to add a pipe connector for any model state, It works fine. In this case connectors are added for all model states, not only for an active model state. I think it would be right to add connectors in the Master model state.
3. If connectors have been added in a model state and then I refresh a substitute based on the Master model state, connectors are appeared in all substitutes. If I refresh a not Master-based substitute, connector are not appeared.
Best Regards,
Artem Marinin
johnsonshiue
Hi Artem,
Many thanks for the additional detail! Something is wrong for sure. It was reported as INVGEN-67514. This defect is still being investigated. We are actively working on a fix.
Thanks again!
