Inventor Forum
Crash creating 2d contact joint
6 REPLIES 6
etfrench
283 Views, 6 Replies
Inventor is crashing while attempting to create the 2d contact joint between the bbInside part and the Follower_Inner_250 part.
ETFrench
6 REPLIES 6
johnsonshiue
in reply to: etfrench
Hi Ed,
Indeed, I am able to reproduce the crash. Somehow, the Dynamic Sim 2D Contact Joint does not like the close spline loop. I cannot explain it. But, I find a simple workaround to avoid the crash though. I create a workplane passing the seam edge and then split the faces (see attached part). If you replace the part in the assembly with the attached part, it should work better. Please try it out and see if it works for you.
Many thanks!
Software Test Engineer
etfrench
in reply to: johnsonshiue
Unfortunately, that didn't work too well.  The ellipse was malformed.  It was originally created in Fusion 360 as an ellipse, then exported as dxf (Attached as bBoxInside_10.dxf).
As you can see the right side of the middle and inner ellipses don't match the right side. The innermost profile is more or less accurate (It's the center of a bone).
I have managed to recreate the ellipses as splines using a 2D cad program (Attached here as BBoxInside_003d.dxf).  The Inventor part (Attached as Part17.ipt) ellipses appear to be correctly formed, but can't be extruded.
This project is rapidly going downhill Smiley Sad
ETFrench
johnsonshiue
Hi! Did you try using the part I attached and see if you still reproduce the crash? Regarding the ellipse, couldn't you use Ellipse tool in Inventor to create it?
Many thanks!
etfrench
The crash did not occur with your modification.  Ellipses aren't allowed in 2d contact joints, so it would be pointless to try to use one (assuming the error messages saying that are correct).  I did replicate the ellipses in Inventor with splines, however 2d contact joint doesn't seem to like those either
Selection:
Resulting error:
Part file is attached.
ETFrench
etfrench
In the previous failure, the model was created with splines in one quadrant, then those were mirrored to create the full model.
In this failure, the splines were created around the full 360 degrees.  Even though splines were used, the 2d contact joint is interpreting those as ellipses, which of course fails:
ETFrench
etfrench
This morning, the full ellipse created with a single spline worked for the 2d contact joint.
This only leaves the dxf ellipse offset and the dxf spline import bugs as unresolved.
ETFrench
