Counter sunk holes on dxf
Yashasvi23481
Yashasvi23481
Hi All,
   A quick one. How do you show countersunk holes on dxf ? do you show both hole sizes (opening at top and through hole) or just the smallest dia. I usually accompany dxf with pdf so details are countersunk are sent to cnc operator. I would assume, if you show smallest hole dia which is through hole they can countersunk the top end, is that right ? Just not sure.
Thank you for prompt response in advance.
Yash
Xun.Zhang
Hello @Yashasvi23481,
Not pretty sure if Inventor HSM can help you or not instead of DXF export.
Xun
Yashasvi23481
Hi Xun,
   Is Inventor HSM available on 2018 version ? I am on 2018 version. If so how to use it and where to find it ?
Yash
johnsonshiue
Hi Yash,
You may want to go to HSM forum and ask.
Many thanks!
Software Test Engineer
Yashasvi23481
Thank you Xun and Johnson,
   Will check with HSM forum. Will mark it as solved for directing me.
Yash
